Mustang 4.6 Engine & Transmission
blown90
35
New York
This is what this COMPLETE engine has; after market BBK 78mm throttle body with plenum, 30lb. injectors, Comp cams 268 extreme cams, Comp cams valve springs, seats and new valve seals. The block is from a 98 stang with 50K miles and the heads are PI giving the motor 10:1 compression. Also included is an 04 Cobra mass air meter, Steeda velocity stack & SCT tuner with a $750.00 Dyno tune for this motor on it! Runs very strong!
Tremec 3650 with 50K, King Cobra clutch & Steeda shifter.
The motor work, seals, gaskets and clutch were done less than 6 months ago.
$2800.00
