mustang 5.0 wount turn over after swaping engine and trang into AOD shell?????
PapiStang50
Eutis FL
i own a 90 mustang vert that was a AOD car, but was converted to 5 speed. i bought a 90 Hatchback shell with out motor or thans that also was a AOD. i swaped over the motor, trans, clutch and brake padels, clutch cable, got all the wires ran and went to start the car but nothing happend. the fuel pump kicks on and the starter solenoide gets power. so i bought a new solenoide just to make sure if it went bad, but still got nothing. i bought a new starter, put it in and still got nothing when i turned the key. i can jump the solenoide with a screw driver and it will start up. i cant think of anything that the problem could be....
You say the starter relay is getting power... are you SURE? Did you pull the little red wire off the small post of the starter relay and test for 12 volts when the key is turned. If you don't have power at that wire when the key is turned to crank the engine, then you probably don't have the neutral safety switch hooked up. On an AOD car, there is a wire that runs from the ignition switch to a round plug with 4 wires on the drivers side of the tranny that is plugged into a switch screwed into the tranny that will only send power to the starter relay if the tranny is in park or neutral. The other two wires in that plug turn the back up lights on when the tranny is in reverse. On a 5 spd car, a wire from the ignition switch goes to a safety switch on the clutch pedal. It will not allow power to continue to the starter relay unless the clutch is pressed to the floor. I'll bet if you start checking for those things, you will find the problem. Hope this has been helpful.
Pull the small push on connector (small red/blue wire) off the starter solenoid (Looks like it is stuck on a screw). Then jump between the screw and the terminal that is connected to the battery. If it cranks, the relay is good and your problem is in the rest of the circuit.
Remember to check the ignition switch, neutral safety switch on auto trans and the clutch safety switch on manual trans cars. If they are good, then you have wiring problems.
Here's a diagram of what capri debris was describing...
Typical start circuit...
attachment.php
sorry havent replyed but, i did get the car to turn over and run. i fergot about the neutral safety switch. but now i have another problem that i have been working on, the car runs and drives but its running rough. idle jumps up and down and when you rev it up it doesnt sound so bad but you can notice it. when you drive it it sounds like its running off seven cylinders.i have replaced the injectors and the harness off the other car. checked the spark plugs and it still runs rough...
A cylinder balance test is not a compression test. In a CBT, which is done after KOER codes, the EEC deenergizes injectors one at a time to find if a cylinder is not contributing as it should. The results don't necessarily mean that cylinder's injector is bad, but it does tell you which cylinder(s) to concentrate upon (to find your miss).
Your repair manual should cover doing a CBT, and JRichker has a write-up about it.
Good luck.
As suggested...
Cylinder balance test:
Warm the car's engine up to normal operating temperature. Use a
jumper wire or paper clip to put the computer into test mode. Start
the engine and let it go through the normal diagnostic tests, then
quickly press the throttle to the floor. The engine RPM should exceed
2500 RPM's for a brief second. The engine RPM's will increase to about
1450-1600 RPM and hold steady. The engine will shut off power to each
injector, one at a time. When it has sequenced through all 8 injectors,
it will flash 9 for everything OK, or the number of the failing cylinder
such as 2 for cylinder #2. Quickly pressing the throttle again up to
2500 RPM’s will cause the test to re-run with smaller qualifying figures.
Do it a third time, and if the same cylinder shows up, the cylinder is
weak and isn’t putting out power like it should. See the Chilton’s Shop
manual for the complete test procedure
Dump the codes and see what the computer says is wrong…Codes may
be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check
engine light, or test light or voltmeter. I’ve used it for years, and it works great.
You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes.
Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with
the test jumper in place. Be sure the A/C is off and the transmission is in neutral.
You'll get an 11, then a 4 and the engine will speed up to do the EGR test.
After the engine speed decreases back to idle, it will dump the engine running codes.
check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
If your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method.
There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
attachment.php
The STI has a gray connector shell and a white/red wire. It comes from the same
bundle of wires as the self test connector.
attachment.php
WARNING!!! There is a single dark brown connector with a black/orange wire.
It is the 12 volt power to the under the hood light. Do not jumper it to the computer test connector.
If you do, you will damage the computer.
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's
internal workings are OK, and that the wiring to put the computer into diagnostic mode is good.
No code 11 and you have some wiring problems.
Do a compression test on all the cylinders.
Take special note of any cylinder that shows up as weak in the cylinder
balance test. Low compression on one of these cylinders rules out the
injectors as being the most likely cause of the problem. Look at cylinders
that fail the cylinder balance test but have good compression. These
cylinders either have a bad injector, bad spark plug or spark plug wire.
Move the wire and then the spark plug to another cylinder and run the
cylinder balance test again. If it follows the moved wire or spark plug,
you have found the problem. If the same cylinder fails the test again,
the injector is bad. If different cylinders fail the cylinder balance test,
you have ignition problems or wiring problems in the 10 pin black &
white electrical connectors located by the EGR.
How to do a compression test:
Only use a compression tester with a screw in adapter for the spark
plug hole. The other type leaks too much to get an accurate reading.
Your local auto parts store may have a compression tester to rent.
If you do mechanic work on your own car on a regular basis, it would
be a good tool to add to your collection.
With the engine warmed up, remove all spark plugs and prop the
throttle wide open, crank the engine until it the gage reading stops
increasing. On a cold engine, it will be hard to tell what's good &
what's not. Some of the recent posts have numbers ranging from
140-170 psi. If the compression is low, squirt some oil in the cylinder
and do it again – if it comes up, the rings are worn. There should be
no more than 10% difference between cylinders. Use a blow down
leak test (puts compressed air inside cylinders) on cylinders that
have more than 10% difference.
See the link to my site for details on how to build your own blow
down type compression tester.
alright i got time to work on the car. i got it to run right, all i did was take out the super chip. i took it out ran it around the block parked it. it ran fine but now the fuel pump wount turn on when you go to start the car. so i did the fuel pump test with the jumper wire and the fuel pump runs with the jumper wire in it, but if i take it out it quits, and if you leave it in the pump stays on???? i swaped the relay thats under the drivers seat but still nothing..
Did you jumper the wire on the diagnostic connector under the hood??
