Mustang gt 4.6l supercharged
castilloj_123
Hello Does anyone know what to do.
I have a diablosport trinity and want to modify parameters on a Mustang Gt V8 4.6l 2005 automatic.
I replaced the stock fuel Injectors (24lb/hr) with ones that produce (39lb/hr), added a shelby gt 500 supercharger with a 2" pulley and the stock gt 500 air filter, left the mustang gt throttle body (62mm) and made a custom intake manifold.
I Don't know how or what to modify in the trinity to upgrade the computer and get best results in the car, and also need to know how to measure the increase in hp if its possible with the trinity.
I dont want to Blow up the engine.
Cheers.
You need to either have the thing dyno tuned or at the very least have one of the reputable tuners create you a tune that is specific for your supercharger. Brenspeed, Bamachips, etc. How did you buy a supercharger and install it without knowing what you needed for the computer?
The trinity (or most any handheld tuner) cannot modify enough of the parameters in enough detail to properly tune your new supercharged combination. You will need to have a custom dyno tune done to be 100% safe. A mail order tune may get you close. Dyno shops buy the complete software for the popular handheld tuners (i.e. Diablosport, SCT, etc.). They use a PC to view data logging from a dyno pull and make changes via the PC software that is not available in the rather simplistic handheld tuner. Once they build a tune with the PC software, they will download that tune into your trinity to be plugged in under your dash (OBDII port) for uploading.
