mustang is not running right can anyone help?
mistergee
tx
my mustang seems to be running like **** now, i just put in summit long tube headers , 3 inch x-pipe and single chamber flows, now it was running without o2 sensors at first but now i installed them. anyways the car seems to sputter and it wont seem to go when i give it gas. but this only happens every now and then. also when i get on it there is alot of back fire at high rpms. do you think that it could be my fuel injectors? or maby fuel pump and fuel filter? or perhaps the distributor?
I'm gonna guess fuel pressure regulator on this one... I could be wrong but that's my guess.
Could also be Distributor Cap, distributor, o2 sensors, fuel pump, filter... But considering the exhaust amplified the problem I think you should check the fuel pressure.
I had a mustang do that because of an intake swap. I also wonder if a complete loss of back pressure would do it?
I am having similar problems as well and ine started to do the same thing after a new exhaust. I have been through the whole thing too. Checked everything as far as fuel, spark, and most of the ignition components.
is it a catted or o/r x pipe? did you do it yourself or was it installed at a shop? any chance something was not hooked up right? when i did mine, it seemed to amplifly the problems i had with my egr that i didn't really realize until after, but i also removed all my smog equipment at that same time. it ran rough after the install until i bought a scanner and found my egr was toast....
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
attachment.php
attachment.php
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
