Mustang Plus Suspension
65inworks
101
sacramento,ca
Have any of you guys ever used any of their stuff, I am going to get a suspension kit from them tomorrow. It will includes 620 coils, 5 leaf rear leafs and all new bushings. I'm also getting sway bars, upper and lower conrol arms. Any reviews would be greatly appreciated.
thanks
thye sell good stuff. i wouldnt use their 620 front springs though, i think they are a bit too stiff for the street. i have their 540's though and i think they are right for the street.
mustang plus
I am going to go with the 620's up front and the 5leaf mid eyes in the rear. That is the first I heard about the 620's being to stiff for the street. Let me know how it works out.
thanks
Redid the entire steering, suspension and handling on the 65 FB with M-plu sstuff.
5 leaf mid eye, 620 drop 1 1/8 front 3/4 rear..UCA. LCA, perches, etc.
make sure you upgrade to the KYB gas adjust shocks at the min....the stock kyb are very bouncy.
I like the ride, very sporty.
I Autocross My 72 Stang.
I got their complete setup, but only have 4 1/2 leaf rears, and I love it, corners as good if not better than my brand new 2004 GT. It was an easy install on my car. If I could unbolt it I replaced it. Brakes are next.
I got the kit, plus the steering kit. It took a couple of weekends to finish the install. I have not driven much but it seems to be very good. The car is stiffer but not harsh and the steering feels a lot better. Make sure you have a big hammer, a ball joint seperator, lots of bolt lube for the strut bushings, and a large breaker bar with a deep well socket. Good Luck.
Sir TWIG said:
I got their complete setup, but only have 4 1/2 leaf rears, If I could unbolt it I replaced it. Brakes are next.
Me too and I love it! I think the 620lb springs are just fine on the street, but I think my 73 probably weighs alot more than a 60 something. I'd like to go autocross my stang and I will if I can stop the oil leaks. B.T.W. changing a front seal is no fun! :bang:
hey dodgestang i got a question. did you use one of their suspension kits or did you just pick and match parts?? cuase I want my car to have the same stance that yous has and just wanna know if u did a kit or a mix and match. thanks
Just called them up said:
"I would like you real big kit there, but I want 620s in the front, 5 leaf mid eyes in the rear and the largest sway bars you got. Ohh and upgrade me to the KYB gas adjust shocks"
Other things to note, I have the shelby a arm mod and a little heavier 351c in the front. I recently upgraded to a roller spring perch in the front and eliminate the lower coil spring isolated pad do-hickey thing. I still have the top one in there though.
68coupe408 said:
That's a great stance Dodgestang, but the oil pan will hit everything!
4.75 to the pan
4.00 to the collectors
2k miles and nothing has hit yet.
I drive fast on the highway through the potholes and all.
I do take it easy entering parking lots and driveways. :)
I have not had to go over any speed bumps yet :)
if you have stock brake lines (ie from 35+ years old) order new front brake lines while ur at it. all the manipulating of the spindle to get at the bolts/nuts tore the old stock lines to shreds. also if your going to remove the power steering, this would be the time to convert the new center link (only one trip to the alignment shop;))
i did the full replacement on mine and just like the others, it ride's and drives like a dream. just make sure you check the rear sway bar at 500 and 1000 miles to make sure it hasn't come loose. also on the rear sway bar make sure you get the perches that mount to the rear end as level as possible (they stay tighter).
My only complaint was with the ball joint dust covers (boots) on all their products. The rubber on all of their supsension parts dry rotted within one year. I did not even have the car on the road and noticed the boots had major splits and cracks in them. I am now slowly replacing them with poly boots and will not buy their suspension products again.
Great68 said:
Wow dodgestang, your car makes me want to lower mine SOOOO bad. How's ground clearance? Your oilpan sure looks close to the ground.
I feel like I've been answering this a lot lately...
4.75 to the pan
4.00 to the header collectores.
Nothing hit so far with 2k hard miles on it...I do take it easy entering driveways and parking lots....but I don't baby it anywhere else.
