Mustang Problems
Dai Lapoole
Louisiana
So I have a 2002 mustang. Other day it was raining and I slid into a little pole barely a dent. Car started stalling and finally died. Had new fuel pump installed and fuses changed out. It’s finally cranking up but now won’t turn off and smoke is coming from under drivers seat. Any ideas
Just wondering. Did you check and reset the IFS switch in the trunk? The IFS switch is supposed to cut off the fuel pump after an "impact"?
Exactly WHICH fuses were blown using the following numbering scheme:
1999-2004 MY fuse panel schedule:
https://www.allfordmustangs.com/for...r-swap-wont-fire-please-help.html#post2669271
If this were my car I would be performing a visual inspection under the car and through the door sill looking for any possible wiring harness damage.
