I just noticed my car is not the same height on the driver rear as the passenger side... and this had actually cause the rear driver tire to be chewed up a bit by the fender. It looks level from the back. I don't see anything obvious...
your leaf springs are saggy ( 40+ years old? ) that's all.
do you carry a passenger every time you drive it? : )
But one more than the other?
Try loosening and re tightening the bushings while on the ground. You may have overtightened one side while lifted.Nope... Its only a 2 seater now... the back seat was removed to house speakers and a battery relocation. The car hasn't been driven in 3 years. Just got it finished this past week... but like I said never did redo the springs... just the bushings. I'll try to get under the car tomorrow to check the leafs and eyelets... I just want to know if one spring can be worse... and if not what else the issue could be![]()
I ended up buying a kit from Mustang's Plus with a set of 4.5 Mid-Eyes, and I'll be rolling the fenders in all 4 corners with a Eastwood Roller and Heatgun this weekend.
Now my question is... I have the original leaf springs and 1 inch drop blocks on them. The new leaf springs have a 1 inch drop since they're mideye... but my old ones were already sagging. Do you think I'd be at the right ride height if I kept the drop blocks in place, or eliminate them since the leafs are lower than stock????
You will have to experiment. It's hard to tell how much the springs have actually sagged. Also, keep in mind that new springs will sag a little during the 1st couple of months of driving. So I wouldn't mess with the ride height until you've had a chance to put a few hunded miles on them.
I had the same problem. After replaceing the rear leafs, is still was lower on the drivers side (but better). I had to replace the front springs before it was fixed.
If you take it to a collision shop they should be able to tell you within 1hr. We do it pretty often here. I have seen it be the frame twisted to the mounting points of the suspension just not level throwing it all off. I don't think we've come to the conclusion yet it was springs on any car. The mounting point on my driver side eyelet in front of my leafs was 3/4 inch lower on one side. Making it lean. Everything else on the car was withing 1/8in.
