Mustang Stalling
  • Thread starter Thread starter dbdragracing
  • Start date Start date Aug 15, 2006
dbdragracing
397
Aug 15, 2006
  • Aug 15, 2006
I have noticed latley that my '89 GT will start and immediately die. I noticed if I held the key in the on position it would keep running, but as soon as I let it go it would turn back about 1/8 inch and die. What do I need to replace to fix this? Also the ignition module right below the key, I think it needs to be replaced to get my turn signals working again...is this just a plug and play install or do I need to program it? Thanks.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 15, 2006
  • Aug 15, 2006
The ignition switch is the likely culprit. It will also affect the turn signals.
There is a FREE recall on Ford ignition switches. They overheat and sometimes catch fire.
Copy down you VIN number and call the Ford dealer nearest you. Tell them you want to see if the ignition switch recall for Fords & Mustangs was done on your car. They will ask for the VIN number & check it against the master database. If it isn't in the datbase, then you can schedule an appointment to have the switch replaced for free. The TSB is #95S28, and don't let them tell you that they don't do that anymore...
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
W
1993 LX 5.0 dies after ignition parts replacement
  • Warhorse85
  • Aug 16, 2025
  • 5 6 7
5K
Fox 5.0 Mustang Tech Nov 4, 2025
General karthief
W
I need a 1997 Mustang PATS A expert!
  • Wolfdogg
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
