mustang weight reduction?
Sorry to say there isnt any real single thing you can do to drop a massive amount of weight. You just have to do a bunch of things that add up. There are several hundred pounds to shed, but its expensive if you do it all. If you did go through it all though, you would have a car that could handle on ice.
I totally agree....! 3140 with driver (200lbs) 268 rwhp and mid 12's all day long...................Suspension components are the key and will also make your car lighter and handle better...
"ED"
Didn't you see my riviting "lost 29lbs" thread?:eek:
http://forums.stangnet.com/showthread.php?t=691642
Seriously though, my stock (H) midpipe was very heavy compared to the aftermarket Bassani X - not sure exactly, but it has to be in the range of 10+lbs. Also, as the others said, suspension and wheel components are where the weight matters probably the most is a great place to look to. Aftermarket (light-weight) LCAs and/or UCAs are a good start.
These are some of the things I have done. Car weighs 2880 pounds plus driver...
Aluminum block
Replace 4R70W with C4 tranny
Remove front and rear bumpers
Tubular k-member, a-arms, and coilovers
Lift-off hood
Remove fog lights
Remove horns
Remove windshield wipers and motors
Light weight drag wheels including skinnies
Remove a/c, heater, power steering, power brakes
Remove airbags
Aftermarket steering wheel
Remove metal plate below steering column
Lightweight drag brakes
Remove door bars
Remove radio, CD, amp, radio speakers
Remove A/C and heater control panel
Remove sun visors
Light weight drag seat
Remove passenger seat
Rear seat delete
Dumped Dynomax Race Bullit mufflers
Remove charcoal fuel cannister
Replace fuel tank with 5 gallon fuel cell
Remove carpet backing
Remove everything from the trunk
Remove wing
These are some of the thing I have done. Car weighs 2880 pounds plus driver...
Lift-off hood
Remove fog lights
Remove horns
Remove airbags
Remove door bars
Remove radio, CD, radio speakers
Rear seat delete
Remove wing
Still a daily driver?
