mustant sputter
  • Thread starter Thread starter foxracer18
  • Start date Start date Jun 21, 2005
F
foxracer18
Hill Valley, Pa
Jun 21, 2005
  • Jun 21, 2005
I have an 88 mustang with gt- 40 head .30 over with a mild cam. I bought the car the way it is with 350 horse with 24ib injectors with a roll cage racing seats and lots of extras. Their is aftermarket mass air sensor on it bt a stock throttle body. I think i mass air sensor is broke oh. Would that make a miss when u gun the the throttle? I unhookd it and it runs better but still has a miss what could it be? It rain fine when i bought it. Could a hole in the exhaust cause it? Any help would be great. Thank You
331 stang91
261
wisconsin
Jun 21, 2005
  • Jun 21, 2005
I had a problem like that and it was the tps censor check it to see if it could be way off or bad. Especially if you tried to change the timing or something. It's the easiest thing to check off you list.
F
foxracer18
Hill Valley, Pa
Jun 21, 2005
  • Jun 21, 2005
thanks
Thanks i will try that.I hope it helps do u think i also nd to replace the mass air
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 21, 2005
  • Jun 21, 2005
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $33.
331 stang91
261
wisconsin
Jun 21, 2005
  • Jun 21, 2005
I'f the mass air was broke I think you would be haveing very serious problems not to say its not the problem. You should try to pull the codes. Maybe then you can see if its spark or fuel related. That will help you marrow it down.It seems like you recently bought the car? I'f so maybe contact the old owner he may know some of the things that were in need of replacing? Hopefully if he's not a jerk he'll help you.Good luck keep us informed.
G
Sputtering/misfiring below 2500rpm
  • Godless
  • Sep 14, 2025
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2025
gkomo
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
Fox Mass Air Flow 42lb injectors
  • 89wreck
  • Aug 18, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 5, 2025
Scrapla347
