my 5.0 is doggy I NEED HELP!
JGriff
Central WI
hey guys,
Im new to the site, but not new to Mustangs.
For some reason that IDK my car is doggy and sounds like it backfires on me, but it only does it sometimes. If I take off and get on it through all the gears its perfectly fine. but if I'm cruising through town and then get on it between 2-3k rpms its bogs down is a little jerky and sounds like it backfires a few times, same as if I'm going down the highway and then put it to the floor. Anyone have the same problems? I have a few ideas...but looking for a good starting point to figure this problem out.....love to hear anyone advice!!!!
Dumping The computer diagnostic codes on 86-95 Mustangs
Revised 19-May-2009 to update drawing for dumping the codes on 86-88 Mustangs with no check engine light.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
here is a list of work done to the motor
Edelbrock RPM Performer Intake manifold
BBK valve covers
BBK long tube headers and H-pipe
2.5" Flowmaster stainless exhaust
AEM Cold Air Intake w/K&N Filter
24# injectors 190lph fuel pump
70mm Throttle Body
Accel Coil Pack
Underdrive pulleys
NOS Nitrous Oxide System with purge
AC Delete Kit
Aluminum fan and water pump
Tremec 5-speed Transmission
3.73 Gears with full posi rearend
Steeda Short Throw Shifter
and this is all the suspension
Steeda sub-frame connectors
Steeda front and rear sway bars
Lakewood brakes all around
Caster/Camber plates
Eibach 1.5" lowering springs
BBK Polyurethane Bushings
Lakewood Struts
so far I haven't tried anything since its been parked for winter due to cold and snow in Wisconsin. so i guess if anyone out there has any ideas let me know...im thinking about supercharging it or stroking it out, or both. any input on any of this would help, also considering the 5 lug conversion, but not sure of the benefits besides being able to put saleen rims on it
ummm....dumb response here by me....but I'm not sure, I dont think I have it because I have complete exhaust from the headers and dont think it would be back on after removing all the exhaust???
No EGR has to do with return gas. Best bet is to run codes. Oh and mine does the same thing with less than a quarter tank of gas so I make sure I never go under that, I assume you have a full tank of gas. Could maybe, possibly you have bad gas?
