My 89 won't idle when cold
KENS89LX
302
Cross lanes Wv
After installing a March ram air system on my stang a few weeks ago the motor won't idle, so far I have installed a new rotor cap and button, cleaned the egr valve, adjusted the timing, and the tps but it did not help the idle when the engine is cold, it is fine when it warms up. It also bucks a low rpm's. :shrug: :SNSign: What next?
I"ll try that, I just tried switching the IAC motor but it did'nt change anything. I have the c&l 76mm mass air meter and a 70 mm throttle body, would it make since the it is getting more air than fuel since the onle thing I did tto the fuel system is a 110 fuel pump. Would the stock mass air help?
Just pull out the electronics(two screws) clean the little wire that measures air flow, and put it back together. If that dosen't work, try roatating the meter. does that cold air kit have a 90deg elbo in front of the meter?
Nate
When using some aftermarket IAC's, check instructions to see if it needs to be mounted upside down. If it isnt, the car wont idle decently or at all while cold.
I would run codes. If needed, go through and reset your idle.
Good luck.
not to jack the thread or anything but im also having the same rough idle problem, it does it in the morning when cold and it bucks below 2200...i cleaned the MAF, put a new IAC in, new plugs, cap & rotor. i also have a C&L MAF and intake tube.
See the sticky "Help me create the Surging Idle Checklist" at the top of the forum for help with your idle problems. The first most contains all the updates to the fixes. I continue to update it as more people post fixes or ask questions.
Have you pulled the codes???????
Please do this first.
We (humans in general) can only take guesses. Even though they are educated guesses, the computer can give you more concrete information to work with.
(the above suggestions are all good)
Not all trouble codes will trigger the check engine light.
I'm not trying to be a jerk, and I apologize if I have come across that way.
I know how frustrating it can be to diagnose these things.
Good Luck,
jason
I have the same problem with mine.... It will surge from about 500 to 2200 when i first fire it up. I pulled the codes and got nothin... basically i just got pretty good at how i touch the gas and when to touch it and i can usually get her to idle in a few seconds. Bascially a quick fix is just to play with the pedal some when shes cold.. atleast it works for me, after its warm she'll idle all day
As I said, see the sticky - some of Stangnet's best & brightest have contributed their experience to solving the idle problems common to 5.0 Mustangs.
You indicate the issue started after the march kit install..I'm wondering if maybe you damaged or knocked off one of the vac lines around the area of the emissions equipment creating a vac leak. Next would be if the kit install created the issue..what happens when you go back to your previous set up
I don't have a code checker.. I just came in from cleaning the wires on the mass air, and the throttle body, and it was gummed up. If that don't work I am going to go to autozone to get the codes if there is any. Does anyone have the gt-40p heads on their stang? I am having trouble finding plug wires that fit without being very close to the headers, I just found two more that was burnt and cracked.. could have been my surging problem.
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
By the way - this information is is the Surging Idle sticky...
When I switched to shorty headers I had to convert to plug wires with a 90* boot (as opposed to the stockers with a 45* boot).
The 90* boots I have are also much shorter than the stock units.
I have has no plug burning issues since.
Shorting out the plug wires can cause some major issues, but I would still look at the codes.
I check my codes at least every oil & filter change, sometimes more ofetn. Probably overkill, but it is so easy to do I figure why not.
I bought one of these scanners... http://www.autoxray.com/products.aspx?sub=readers&id=33
Some of them are affordable.
jason
Checked the Haynes book on different plug situations by pic, says caused by either bad valve seals or bad gas. I'm thinking it is the gas, where I "used" to get it it had 10% additive in it, I think it was ethanol but not sure. Dose anyone run 89 octane that is what I am using.
