My balancer doesn't go on like it did before
  • Thread starter Thread starter Nicoleb3x3
  • Start date Start date Apr 25, 2009
  • 3
First Prev 2 of 3 Next Last
95Vert383AOD
1,133
34
69
New Bedford, MA
Apr 28, 2009
#21
  • Apr 28, 2009
  • #21
Nicoleb3x3 said:
I was hoping comp cams could verify it's WRONG, but today they said this is the correct gear.
Because I feel there's not much else happening with this installation, I going to pull the cover this weekend.
I have the old gear, once I pull the cover I'll know for sure either way
unless anyone else has any other ideas?
If i was just a little closer i would go and put it on myself for you. I put chains and timing covers on in my sleep.
Nicoleb3x3
274
southern NH
Apr 28, 2009
#22
  • Apr 28, 2009
  • #22
all of this was easy up until this point! lol
S&B
I hate my CT. :(
1,634
695
204
Cheesehead
Apr 29, 2009
#23
  • Apr 29, 2009
  • #23
well when my balancer wasn't seating properly I removed it, and headed it up with a torch not glowing but heated up good, and hot. Then and only then did the ballancer slip right on and bottomed out, I put some locktite on the bolt and it hasn't caused me a problem since
Nicoleb3x3
274
southern NH
Apr 29, 2009
#24
  • Apr 29, 2009
  • #24
mine is definately bottomed out....you can hear a solid "thunk"
it fits easly on there....
Nicoleb3x3
274
southern NH
Apr 29, 2009
#25
  • Apr 29, 2009
  • #25
my imagination or what? lol
timing cover is comming off
95Vert383AOD
1,133
34
69
New Bedford, MA
Apr 29, 2009
#26
  • Apr 29, 2009
  • #26
Where did you get that timing chain set???
Nicoleb3x3
274
southern NH
Apr 29, 2009
#27
  • Apr 29, 2009
  • #27
comp cams...I have the box in front of me.....new in the box # 2138
Nicoleb3x3
274
southern NH
Apr 30, 2009
#28
  • Apr 30, 2009
  • #28
I'm so pissed I lost so much time over this stupid sprocket...so what now; wait another week to get a replacement...no reply yet from comp cams- I'm so pissed. I've never built an engine in my life; I have enough to worry about; not this stupid thing
S&B
I hate my CT. :(
1,634
695
204
Cheesehead
Apr 30, 2009
#29
  • Apr 30, 2009
  • #29
its a car, a mustang none the less, at least you found the problem. sometimes i wish i would have gotten into working out or something, wouldn;t be this stressful.
let us know when she's up and running
Nicoleb3x3
274
southern NH
Apr 30, 2009
#30
  • Apr 30, 2009
  • #30
If this turns out to my my biggest problem...I'll be happy
95Vert383AOD
1,133
34
69
New Bedford, MA
May 1, 2009
#31
  • May 1, 2009
  • #31
Put that sprocket on a diet!!! It looks kinda fat from here.
I agree if thats your worst issue with this swap then you're lucky. Besides mild fitment/ electrical issues with the swap.
"You can do it" ~Rob Schneider
Nicoleb3x3
274
southern NH
May 1, 2009
#32
  • May 1, 2009
  • #32
ok, I'm pissed off right now
comp cams told me that...oh you should have probably purchased #2120 -that's 65-88
the one I got is 84-92 and "you really need to watch out for those Ford engines" and "you should check the parts before you install them"
So; there's an overlap with the fuel-pump eccentric and specs on the pre-89 engines- wow!
So; basically I bought this timing set as part of a package SK35-514-8 that included my cam, lifters and the timing set. I did this for simplicity and I would know the components are matched up nicely. Now this guy says...this timing set may not work on EVERY 87-88 engine? Why wouldn't they drop this warning anywhere on their site or instructions? Why only offer one set for the 87 and it NOT cover every 87 engine? So; I was doomed from the start.
So, they won't take it back; I eat the cost and I'm stuck buying another timing set.
Can someone tell me...can't I just get whatever set from the local parts store? I'm done with comp cams timing sets- screw that. I don't think the timing set matters as long as it fits the MY ENGINE.
errr, wtf; seriously this is not what I expected them to tell me.
And...I am not comfortable buying their set #2120 as who the hell knows if it really fits my engine or not- I'm not EATING THE FREIGHT BILL on a second set that doesn't work out.
95Vert383AOD
1,133
34
69
New Bedford, MA
May 1, 2009
#33
  • May 1, 2009
  • #33
WOW that sucks.....Know what you do if you want to get them back??? Return the timing chain that doesn't fit in the new box!!!!
Ok, so im a bad man...but hey....its cost effective!!
Nicoleb3x3
274
southern NH
May 6, 2009
#34
  • May 6, 2009
  • #34
ok, new update; I got another timing set....this one specificaly for the 1 pc fuel pump eccentric...which I assume is the application note that I'm missing...and....this new gear is now yet a third overall thickness....it closed HALF OF THE GAP but not all of it.
So what the hell is going on? Do I just install it anyways at this point? Try to load up on the silicone and get the timing cover to come outward as far as possible? Maybe torquing it down will close the gap more? either way, I can tell by the gears that this one is only HALF way to what i was looking for. WHY IS IT SO HARD TO FIND A TIMING SET FOR THIS DAMN ENGINE? Dammit ford...they stopped using the 1 pc fuel eccentric in 84, and phased it out through 89- why is it so difficult to get this to work? At what point do I install it based on a leap of faith I won't leak at the front seal?
strtrcr50
Previously from Dirty Jerzey exit 7a
May 6, 2009
#35
  • May 6, 2009
  • #35
Well, you've convinced me not to get a comp cams timing set when I get to that point in my rebuild. And, no, I wouldn't load up on silicone and hope for the best.
Nicoleb3x3
274
southern NH
May 6, 2009
#36
  • May 6, 2009
  • #36
this new set is from Cloyes....! it's "close" but no cigar!
Wtf am I supposed to do?
strtrcr50
May 6, 2009
#37
  • May 6, 2009
  • #37
I can't remember at the moment.. Is it possible to put the thrust bearing(#3 main I think) in backwards?
Nicoleb3x3
274
southern NH
May 6, 2009
#38
  • May 6, 2009
  • #38
hmmmmmmmmmmm....god I hope not! It's on the #3....
but I can see the difference directly when I look at these crank sprockets...so I have no idea and i'm kinda sick to my stomach now.
Nicoleb3x3
274
southern NH
May 6, 2009
#39
  • May 6, 2009
  • #39
yeah,... no I couldn't have...the tabs and the oil hole; no way is it wrong.
strtrcr50
May 6, 2009
#40
  • May 6, 2009
  • #40
Just the odds of 2 separate companies sending the wrong timing gears aren't very high. One more thing. Does the rear main seal ride the crank in the exact same location as before? Also, did you center the thrust bearing?
  • 3
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
  • dan50
  • Jul 18, 2026
dan50
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
