  • 1994 - 1995 Specific Tech
My car doesn't start, acts like a bad battery but I dont think it is.
  • Thread starter Thread starter BlueOvalStangGT
  • Start date Start date Feb 1, 2007
BlueOvalStangGT
2,849
Tampa Florida....USF!!!
Feb 1, 2007
  • Feb 1, 2007
Its done this before, but usually after a little fiddling it fixes itself. Here is the symptoms:
My viper alarm doesnt work, wont unlock doors, siren tries to go off, and just acts plain weird.
Lights are a little dim maybe, not too bad
Headlights and everything turn on and are bright.
Now when I turn the key to start it, it acts exactly like a dead battery. All the lights go out, the starter ticks(but motor doenst turn over), etc.
When I hook jumper cables to it my alarm works perfect, I can arm and un arm it. Lights are bright,etc, but when I turn the key its the same thing, acts like a dead battery but the car will BARELY turn over.
I took a multimeter to the battery and its 12.6 volts, or like 14 with the jumper cables to another car.....so I dont think its the battery. What could this be?
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Feb 1, 2007
  • Feb 1, 2007
If the battery has 12.6V, and jumper cables fix the battery voltage problem but not the starter problem, I would say the engine/main grounds are not connecting well. Re-do all the grounds and even add a new one. That should do it.
I believe that the starter grounds to the chassis, and if the motor ground is not good, current will not get to the battery ground terminal.
Not that I think this is the main problem, but how are the main connections to the battery? Cleaned them lately?
Scott
Bosko5.0
1,067
longwood, FL
Feb 1, 2007
  • Feb 1, 2007
try cleaning terminals and make sure their tight same thing happened to me and one of my connectors was broken.
HISSIN50
34
129
Feb 1, 2007
  • Feb 1, 2007
Scott
This was going to be my tact too.
You can use a jumper cable from the motor to the chassis as a test ground to see if it helps. Ditto for running a jumper in parallel with existing power cables. When the car acts normal, you know the paralled cable is deficient.
Good luck.
BlueOvalStangGT
2,849
Feb 2, 2007
  • Feb 2, 2007
Thanks guys! I cleaned the pos, neg and the two grounds near the battery (I have some sears brand terminal clamp things and the neg one was a little loose) and then it started right up! Also switched the wheels while I was at it! Thanks again!
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Feb 2, 2007
  • Feb 2, 2007
Not a problem. Glad it was a simple solution.
Scott
P
Crank but no start BUT no power to gauges
  • project_88LX
  • Jan 13, 2025
Fox 5.0 Mustang Tech Jan 14, 2025
Mcmahst
Crank no start, I’m stumped!
  • Seth Brogan
  • May 18, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 14, 2026
BossHorseGirl
9
1995 Mustang GT Crank no Start
  • 95gtV
  • Sep 1, 2023
3K
1994 - 1995 Specific Tech Dec 4, 2023
SRago
Car popping car starts up but wants to die if I don’t hold pedal down
  • Creomod
  • Mar 25, 2024
3K
Fox 5.0 Mustang Tech Jun 16, 2025
AeroCoupe
O
Resolved New here, bad electrical problems
  • Oxfordwhite01gt
  • Oct 12, 2023
1996 - 2004 SN95 Mustang -General/Talk- Oct 14, 2023
Oxfordwhite01gt
O
