but its not, all the ignition stuff is new(ish), plugs, rotor, cap and wires were changed this past fall. swapped out the coil with a known good one and put a new distributor in today. timing is at 12. the car feels like it bogs then with a little more pedal will take off like nothings wrong. sometimes it will backfire once after it bogs then drives fine. At part throttle it has what feels like a small surge at about 15-1700 rpm.
fuel pump has about 10k on it and the filter was changed this spring. the only code its giving up is the neutral safety switch code. did have a TPS code but i changed that and took care of the code. where should i start looking next?
