S Stopsign32v Member May 18, 2008 394 0 16 Gville, SC May 10, 2010 #1 May 10, 2010 #1 What will fix this? When I open the passenger door the light comes on but not when I open my door. Also my door never catches when you open it so it will stay open. Fix my damn ride guys.
9 94gt5.o New Member Dec 27, 2009 177 0 0 ferndale WA May 11, 2010 #2 May 11, 2010 #2 I would check your fuses and the check your bulbs as for the door idk what to tell you. On another note i read the 331 build very badass man good job.
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 34 129 May 11, 2010 #3 May 11, 2010 #3 Look at the door pin switch to see if it's broken. The door slamming shut on you is common. The little roller is probably worn.
ProKiller Founding Member Apr 26, 2002 3,064 15 78 PA May 11, 2010 #4 May 11, 2010 #4 I'm with Hissin. the rollers wear out but they aren't an easy fix if i recall.
