My new plan of action
OonDeanisS
902
Danbury, CT
Some of you know my friend got hurt pretty badly, and seeing him like this made me think about all the things i havent done yet that i really want to do, including fixing up my blue mustang. So i made a list of EVERYTHING i need to do to my 86 coupe to make it as nice as the next, so here it is, i think i got everything.
Disassemble engine
Paint black: heads, alt, P.S., tensioner, Water Pump
Paint silver: Intake, Valve Covers, Carb, Headers
Install Poly Motor & Transmission Mounts (& change trans. Fluid 2.8q ATF)
Disassemble Engine Bay
Remove overflow tank, Fan shroud, radiator, coil, s.s., MSD, battery, & wires.
Wire-wheel, prime, & paint engine bay & engine block black.
Reassemble Engine Bay
Install radiator, fan shroud, overflow tank, coil, s.s., MSD, battery, & wires
Reassemble Engine
head gaskets & block end gaskets
Heads& valve covers
Header gasket & headers
Dipstick tube
Manifold Gaskets
Intake manifold
Oil
Distributor
Gasket, spacer, gasket
Carb & fuel lines
P.S, Alt, & tensioner
Belt & radiator hoses
Heater Core Hoses
Spark plug wires
Disassemble Interior
Remove seats, doorsills, carpet, panels, moldings, light, & headliner
Dye Headliner black
Wire-wheel, prime & paint door jams
Paint tilt lever
Paint window trim in & outside black
Paint Trunk jam black
Tighten steering column
Assemble Interior
Install black seat belts
Black headliner & light
Black Visors
Moldings
Black carpet
Doorsills
Black seats
Dashpad
Steering column
Tachometer
Apillar gauges
CD Player & wiring
Body Work
Paint inside of trunklid black
Install new trunklid & Hood
Install new RH fender
Paint lower half of front bumper black
Install front Air Dam
Bondo dings on doors & rusty spots of QP
Bondo front ford emblem & trunk keyhole
Cut & Weld on new LH lower quarter panel
Remove fuel gauge & louvers
Mask off windows, mirrors, & tires
Remove head & taillights
Sand entire car
Wipe clean, Prime & Paint
Install fuel gauge & Louvers
Install Lights
Cut & Install old springs
oh, these are the alternator wires, can anyone tell me where this red wire goes?
