Son of a bitch.
So I had no problems with the car, started up every time, runs, idles nice, re-starts without issue. I installed the gauge pod with a tach, boost gauge and wideband, all autometer ultra lites. Took the power from the wiper motor (fused, of course) and hooked up the green tach wire to the ground on the coil. Tapped a vacuum line just off the tree for the boost gauge. Did not run any data logger, so it was just power to the WB, and of course the sensor and it's hook up.
After it was all done, I tried to fire it up, it started but ran like crap, I had to pedal it alot just to keep it going, then it wouldn't start at all, just turns over. So I pulled the fuse out of the gauges, and removed the tach ground. Still nothing. Everything in the ignition is new, coil, cap & rotor, dizzy, plugs, everything.
Plugs are wet, getting lots of fuel to the rails, but now no spark??? Nothing else was changed, just added the gauges.
Any suggestions?
edit - I have 12v at the red wire on the coil to a ground when key is in run position, but not between the red/green wire, is that the ignition relay?
Any suggestions?
