my QA 1 struts came.....heres the problem!
jackchan
507
Mobile Alabama
my QA 1 adjustible race struts came to the only problem is there isn't any hardware with them??? Has anyone here used QA 1 struts and if so did you use your stock hardware (ie rubber bushings, washers, nut?)
thanks in advance
Jack
what about the 1 foot long rubber boot that goes around the top of the strut under the fender? do i need to also reuse that?
thanks for the reply.............
A little pressure will mess a guy up trying to think straight.........hell I may even have to have a picture illustration....before i can think straight lol
I leave for Bradenton in 3 days........and have a ton of stuff to do yet! thanks
Jack
I've never reused the dust boot..acutally, when I bought my car it had aftermarket struts on it and the dust boot wasn't on there. If you still have yours, its probably best to put it on the new struts so they will last as long as possible. I haven't had any problems though.
So wait a minute... you bought new struts but you're required to use the old rubber bushings??? That's crap. Call those hosers up and tell em to send you the rest of your stuff.
Rick 91GT said:
Jack you can re-use your stuff but I would get a set of Poly bushings for the top, drop the dust boot.
Where does one find a set of poly bushings for the top? I've been looking. Nobody seems to carry thiese things. I need a set for a set of KYBs that I got used from Tim. Parts stores don't list shock bushings as being available by themselves. I gave up thinking that they only came with the shocks.
ENS-4-7114R $22 @ Summit (IN STOCK)
ENS-4-7114G (BLACK, out of stock till end of the month)
I think they are 15 or 16mm can't remember off the top of my head, many of them use different threads...
If you ever want to modify the rebound or extention on them I know a place ;) We have done that for some class cars along with a rebuild on our own, dad's 93 Cobra had one leak after about 6 months. The guy is a authorized rebuild center and is top notch.
I emptied my PM box or [email protected]
Good Luck in FL, I had plan to fly in to see the race but I am too busy at the shop and a little behind, motors are piling up now that parts are coming in.
the whole dam problem with the QA 1's was that I was trying to use the stock dust boot tops under my fenders with the QA1 struts......and the dam top of the strut was restricted and wouldnt let the rod come thru the inner fender enough to attach the upper hardware. Its on and done now thanks for the help guys!
Jack
