  • 2.3L (N/A & Turbo) Tech
My spit & sputtering problem?????
  • Thread starter Thread starter SMOKEDYA
  • Start date Start date May 19, 2007
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
May 19, 2007
  • May 19, 2007
Ok i posted a month or so ago about my 92 4 banger spit & sputtering. Well i drove it today and it did it really bad! I havent drove the car in awhile cause i've been driving my other coupe to break in the clutch. So i was out and it ran fine as always then the tach started to ficker and flutchuate, started to run crappy spit and sputtering like it was out off timming no gas no spark something to that extent. Then the tach read normal ran just fine? I shut it off got to were i was going got back in (about 10 min later) started it ran like crap tach not reading right. All the way home ran like crap, idols like crap. So i get out with it running pulled the wires off the side of the exhust ( front coil pack) and it didnt change and there was NO spark! Pulled off the electrical connector on that coil pack and same thing no change at all!I then taped on the grey box on the intake (i assume it's the ign control mod?) it say's DIS on it started to run fine. Then went to running ****ty with in like 30sec. So what could it be? I did pull the codes a couple months ago and it gave me i beleive a 90 code? My CEL IS ON BECAUSE IT HAS A T5 SWAP THOSE CODES ARE FOR THE TRANNY SENCERS. When the problem occurs it's like it's missing really bad, also whats with the coil pack and plugs on the exhust side? peace
john
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
May 19, 2007
  • May 19, 2007
2 More things to add i had that box (DIS?) checked out and they said it was good a couple months ago they ran the test on it several times to get it hot. Also whatever code i was getting (90)? it says to contact dealer so i did and they said they dont know cause there books dont go back that far?! peace
john
R
RustBucket
585
Buford, GA
May 19, 2007
  • May 19, 2007
I think you may have read your codes wrong. The 92 EEC uses 3 digit codes.
Also, you shouldn't have a CEL from the T5 swap. I did it in my '91 and never got a code.
Testing the DIS module is hit or miss. I've seen bad ones test good and good ones test bad.
If the module is truly good, there may be an issue with the crank sensor.
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
May 21, 2007
  • May 21, 2007
No i'm preatty shure it was a 90 something code, it was close to a code for O2's. So why 2 coil packs ? The wires on the exhust side did nothing wheni removed it, as well as the electrical connector? peace
john
E
egnorant
160
Deep East Texas
May 21, 2007
  • May 21, 2007
Been there1
I had the same problem and it was the DIS module.
With my T-5 swap I pulled codes for the 3-4 shift solenoid and the torque converter lockup problem. Check engine light was intermittant.
I got a DIS from a PicknPull for $5 and all was well...until my fuel pump gave out!
But that is a different problem!
I fixed this on a friends truck and now they think I am a genius.
Spitting and sputtering with a wild tach.....DIS is the first place I look.
Bruce
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
May 21, 2007
  • May 21, 2007
Ok i will try that i was leaning towards this part as well! There is no bone yards with stangs in them around here. The auto store wants $130+ for them and the dealer wants $300+ peace
john
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
May 22, 2007
  • May 22, 2007
So did it slowly go out? peace
john
N
nofxintx
  • Jun 12, 2007
My car is doing that right now. I have a 93 2.3L and it's doing the exact same thing. When I pull off the bottom left spark plug wire from the coil that's closest to me, the car fixes. It will run fine and then I hit a speedbump or something and the car messes up. I have to pull over and put the plug half way on and it runs great. I just have to be careful though because I got shocked a few times. I know nothing about engines. What's the DIS? I'm going to a mechanic tommorow so I hope he figures it out. I kept trying to figure it out. I cut off the cats, got new belts,plugs,wires,K&N air filter, 40 series muffler,oil change, and new fuel pump. And it was STILL messed up!!! I can't wait to figure this out...
stykthyn
5,232
2,652
223
gainesville
Jun 12, 2007
  • Jun 12, 2007
the DIS is a distributorless ignition system that utilizes two sets of plugs. one is your main bank, the second set fires on the exhaust stroke to burn any remaining fuel to improve mileage and reduce emissions.
Stinger
7,754
24
118
Basehor (Kansas City), KS
Jun 13, 2007
#10
  • Jun 13, 2007
  • #10
Actually both banks fire on the intake and exhaust strokes...
stykthyn
5,232
2,652
223
gainesville
Jun 14, 2007
#11
  • Jun 14, 2007
  • #11
well then I stand corrected, I must have been told wrong.
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Jun 16, 2007
#12
  • Jun 16, 2007
  • #12
Well got a motorcraft ignition module off ebay brand new for $125 shipped! Put it on purrs like a cat and the CEL even went off! Now all i need is to trade someone for a RED 92 steering wheel for my 93 black one! Any takers on the wheel? peace
john
Hickfied
413
Morganton, NC
Jun 16, 2007
#13
  • Jun 16, 2007
  • #13
I have a all red 92 wheel.. 100% factory with the bag... LOL! I've been looking for another wheel....
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Jun 17, 2007
#14
  • Jun 17, 2007
  • #14
P.M sent! peace
john
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
D
2.3l mustang hard starts and bogs and stalls when you floor it from idle
  • declan
  • Feb 19, 2025
2K
2.3L (N/A & Turbo) Tech Feb 28, 2025
declan
D
W
Megasquirt base tune for 94 5.0
  • wrx757
  • Mar 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 6, 2026
wrx757
W
J
Spuddeeing 06 4.0!
  • jester242
  • Dec 22, 2025
2005 - 2014 S-197 Mustang -General/Talk- Dec 22, 2025
jester242
J
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
