- Nov 18, 2007
- 18
- 0
- 0
Hey all
So here my most recent poblem.
I Just put a Holley 4v 4150 single pump carb on my 302 cid engine. The carb was preset I guess to factory specs. I was albe to get the car to run enough to time the engine and I also attached a Tach to perfom the timing. (however, its probably wrong due to the high Idle speed) My spec says that the idle speed for the engine should be around 500 to 800 rpm. I can get it to idle below 1000 rpm. Last time I adjusted the fast idle and accelerator cable it was at 1200. I checked but I dont have any loose vacume lines it seems the more adjusting I do the worse it gets. even when I sut the car off and try to restart it it stalls out
Help!
Help!
