My Stangs first video
:rlaugh: thanks guys, always appreciate complements from fellow stangers, especially when it's about an auto:eek: ,:nice:
talked about my opinions and the labor involved in various threads, so any questions related to this you can post in here or pm me anytime.
B&M external supercooler
3200 stall Spec-Rite 10.5" torque converter
13 quarts of Mobil synthetic ATF
Performance overhaul kit
Hard input shaft
Hard intermediate shaft
Mechanical diode kit
Gasket and Seal Kit
Metal Clad Seals - steel boost valve and sleeve
Ring Kit
Stage II shift kit
Performance Clutches
Performance Kolene Steels
Thrust washer pump
Int. roller clutch
Case connector
Digital range sensor
EPC Solenoid
New and reworked performance valve body
Torrington thrust bearing kit
OD servo piston
Snap ring-overdrive DIR CL WAVE
Overdrive band
Bushing kit
Reverse servo piston and cover
Accumulator piston-direct
New 1-2 accumulator spring and upper/lower piston housing
New 2-3 accumulator spring/piston
New standard oil pan and filter
New shifting linkage and actuator
New speed sensor
Additional external tranny cooler line filter that is slotted for heat exchanging
New gear selector shift modual
All new VSS connectors
A Kooler Kleen flush
http://forums.stangnet.com/showthread.php?t=693684: thread about tranny after rebuild
http://forums.stangnet.com/showthread.php?t=713655: Thread about shifter
http://youtube.com/watch?v=0htlF2pTb5s: Vid of how shifter works
http://youtube.com/watch?v=RAtmpxzL7Qw: vid of 1st,2nd,3rd hard shifts
don't think i wrote a write up on my tranny cooler, but it's been written before. Only thing different i did was install a in-line tranny fluid external fluid filter on the from-tranny-to-cooler line
