I've finally confirmed that my GT40 valve springs are going to bind. I got the solid lifter in at zero lash and as I suspected, there's nothing left of the spring. I couldn't even get the .015" feeler gage in between the coils. We had to shim the springs originally to get any kind of seat pressure but hell, even the seat pressure isn't enough to hold compression right now
So the stock springs are going in the trash.
My cam sheet said that the Comp Cams 986 springs were required. So I looked those up at Summit and it turns out they're double springs.
My question is, will the stock spring retainers work on these things? I have a feeling they won't. I was also looking at this kit that comes with retainers. Will the 375# open pressure be too much?
So the stock springs are going in the trash.My cam sheet said that the Comp Cams 986 springs were required. So I looked those up at Summit and it turns out they're double springs.
