Mysterious problem, won't start....
  • Thread starter Thread starter ebelizard
  • Start date Start date Apr 13, 2010
First Prev 2 of 2
woodsnake
1,352
15
69
Hicksville, NY
Apr 30, 2010
#21
  • Apr 30, 2010
  • #21
In today's world of cheap aftermarket aluminum heads, stand alone fuel injection and coil on plug ignition, why would you use points?
Tim65GT
1,149
West Texas
Apr 30, 2010
#22
  • Apr 30, 2010
  • #22
One quick question, would a points distributor, MSD blaster 2, and MSD 5520 work?
Yes. Since the points are only used for signaling the MSD box, a very small amount of current is going through them, so they will last a long time. The wear from the lobes contacting the rubbing block is still an issue though and will require periodic adjustment.
If it is a stock motor, you probably don't need the extra MSD stuff. A lot of guys here use the Pertronix (or other type) points eliminator. You can always add the high dollar ignition stuff later as you add other engine upgrades and you can still use the Pertronix to fire it.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
May 1, 2010
#23
  • May 1, 2010
  • #23
Even if it is a stock motor I would eliminate the points and put a Petronix in.
tx65coupe
May 2, 2010
#24
  • May 2, 2010
  • #24
I completely agree with the Pertronix Ignitor upgrade. I would do it even if everything else is stock.
E
ebelizard
30
#25
  • May 3, 2010
  • #25
Kind of a dumb question, but will this work with my points distributor and blaster coil to eliminate the box?
PerTronix 1281 - Electronic Ignition Conversion Kit | O'Reilly Auto Parts
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
May 3, 2010
#26
  • May 3, 2010
  • #26
I think thats the same one I have. Looks right. What that will replace is your points. You don't need an MSD box with it but the MSD box will make your car run smoother. If you switch to a duraspark setup you will need some sort of ignition box.
First Prev 2 of 2
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Saturday at 9:20 AM
Dawry Ramos
D
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
