Mystery Cooling Problem
  • Thread starter Thread starter jlangholzj
  • Start date Start date Sep 6, 2012
jlangholzj
Mustang Master
Oct 23, 2006
248
31
93
MI
Sep 6, 2012
  • Sep 6, 2012
So, I'm hoping that this isn't "which one of these is not like the other" but I'll explain.
So, put a 3g on the stang (works AWESOME!) and previous to, i never had any cooling issues (e fans and aluminum radiator). would run about 180* idling around town on a hot (~90) day. Well after putting the new alternator on, when i first run it, it will cool fine but if i stop, shut it off, let it sit for a bit and then drive it, it gets hot. ~210 ish. I'm thinking my t-stat is getting stuck because my radiator is cool to the touch (well warm ish but not as hot as it should be). My temp sensor is on the engine block so I'm assuming that I'm not getting proper flow.
my DUH meter says "what did you change" oh! the alternator....but I don't have a weird ground anywhere and its charging fine.....so my next option is a water pump or a t-stat.
thoughts?
woodsnake
1,352
15
69
Hicksville, NY
Sep 7, 2012
  • Sep 7, 2012
That seems normal to me, that it gets hot after sitting a while. Basically just hot water sitting in an iron "pan"..How long does it take to cool off once you start moving again?
madspeed
Colonel Mustard
1,332
204
a van down by the river
Sep 7, 2012
  • Sep 7, 2012
normal
Sent from my rooted, rommed Galaxy Nexus....
jlangholzj
Mustang Master
Oct 23, 2006
248
31
93
MI
Sep 8, 2012
  • Sep 8, 2012
no no no....difference between heat soaking and sitting. I meant sitting for a good 45 minutes to an hour. The goofy thing is the temp never really comes back down. Even driving on a cool night it still will hang around ~200 or hotter and it gets better if I'm not "on the throttle". It fluxuates pretty fast, which is why i was thinking there's not good enough flow through the block.
Regardless of how long it sits or what order of events i run it in, it will run considerably warmer than it used to.
bartl
217
West Rutland, Vermont
Sep 8, 2012
  • Sep 8, 2012
Check it with mechanical means. Ever consider that the 3G is putting out more voltage than your old alternator and this is throwing the gauge off?
jlangholzj
Mustang Master
Oct 23, 2006
248
31
93
MI
Sep 8, 2012
  • Sep 8, 2012
i did think of that and i also was concerned about a floating ground issue but on an initial start up and drive, I get normal temperatures and functionality. The radiator also seems at the right "hand temp" after it hits 180* or so on the initial drive. Also the gauge itself would be thrown by a floating ground, not a voltage output. The sensor is a resistive load that works as a voltage divider through the gauge. Typical input power to the gauges can range from 5-18V without any issues
bartl
217
Sep 8, 2012
  • Sep 8, 2012
You didn't use any sealant on the sending unit, did you? Also, could it be a mismatch between non-linear/linear gauge/sending unit?
jlangholzj
Mustang Master
Oct 23, 2006
248
31
93
MI
Sep 8, 2012
  • Sep 8, 2012
okay so all i changed was the alternator. All systems were normal previous to this change. I made sure that there were no ground loops and that everything was properly hooked up and wired. Everything previously installed on the car came in a kit, matched sensors to gauges and everything worked fine.
bartl
217
Sep 9, 2012
  • Sep 9, 2012
If it's not something related to the alternator then it has to be coincidental. Where "on the block" is your coolant sensor located, by the way?
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
351w turbo build.... Turbo guys teach me things...
  • Kid wita 5oh
  • Oct 22, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 23, 2025
General karthief
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
