N/A or Blow it
AW0L
I have a 92 gt convert. Right now I'm running an Explorer intake, bbk cold air, 65mm throttle body, 75mm Pro-M maf, 24# injectors with a kirban pressure regulator, and a 190 fuel pump. Sitting on the shelf in the garage is a set of y303s, 1:7 roller rockers, with this I was thinking about an ecam, and equal length headers. I was thinking of either a small single turbo, or a 5-6psi paxton kit as far as forced induction goes. Only looking for mid to high 13s. After its still a daily driver. The aod was upgraded with intercepter internals, the rear end is out of a 88T-bird so I have disc, posi, and 3.73 gears. I have upr basic subframes sitting on the shelf as well. :shrug:
I think if your a good driver and can get traction your 13's goal is possible without the power adder, with the combos you say you have awaiting to install. Look at it this way, you do a power adder then want more and more then you'll need a new engine heads cam etc. Man that **** is like crack! 1 Hit and your hooked! peace
john:p
