Over the winter I've bought I set of Comp Cams XE262AHs and springs which will be going in in the spring. One thing that's been chewing away at me though is the issue of oil clearances on the bearing journals.
I know the cams simply ride right on the aluminum of the head with pressurized oil from the galleries providing oiling. My question is, what is the likihood that the Comp (or any aftermarket cam manufacturer for that matter) will have a bearing journal a smidge too large or too small that will end up seizing or wiping or knocking, doing damage to the head? Or how about thrust end play?
Is there any reason to suspect a potential problem? Any value is taking actual measurements of the bearing bores and journals and making sure the clearances are right? And measuring end-play? Or can one simply assume Comp machines the things right and they'll just drop right in? If they turn freely after the caps are cinched down, is that enough?
