Name these stroker parts
  • Thread starter Thread starter Black1987Stang
  • Start date Start date Mar 30, 2008
First Prev 2 of 2
white 89 GT
281
Tacoma
Apr 3, 2008
#21
  • Apr 3, 2008
  • #21
Had mine done to 28 oz. 50 oz. works too.
Black1987Stang
1,422
Jersey Shore
Jun 21, 2008
#22
  • Jun 21, 2008
  • #22
So I found out it is a 50oz., its stamped on the snout of the crank like Rick said,
I am ordering some parts right now to put the shortblock back together....I'm ordering all new bearings, rings, gaskets and headstuds and whatever else.
What bearings should I get? Clevite77 came out of them
The mains say
R Clevite 77
5.05
MB2121P
.010
Lower
and the rods say
C Clevite 77
5.05
CB634P
.010
They don't have oil grooves in the top or bottom, I would like to get ones with grooves on at least one half, it would seem to have better longevity? there's so many differet series, metal, sizes I'm not sure which is best....
It's going to be a street car and plan on shifting in the 6k area, and boost it in the future.
Rick....or someone that has experience help a man out :SNSign:
Rick 91GT
Mustang Master
95
99
PA
Jun 21, 2008
#23
  • Jun 21, 2008
  • #23
Based on the P series bearing I assume it is a cast crank...
Clevite 509P -010 for the mains (your journals have been turned .010")
Clevite 634P-010 for the rods (your journals have been turned .010")
There is not P-series or soft babit bearing that has an oil groove for the 302 main that I am aware of, ACL may have something or Calico. You may want to contact Calico they sell some nice coated bearings for a little extra insurance although the Clevites will be fine.
Get a nice plasma moly top and a low tension oil ring to free up a little power... If boost is int he future you may want to go with a standard tension oil ring.
Black1987Stang
1,422
Jersey Shore
Jun 26, 2008
#24
  • Jun 26, 2008
  • #24
Rick thanks,
about the P-series, the internals are forged(im pretty sure anyway)....I'll have pics of my buildup attached so you can see for yourself. So IF it's forged these would be the wrong bearings in the first place?
I would just think an oil groove would be better but I guess as long as the oil's pressurized and the crank is turning there won't be any "dry" spots on the bearings, you're the engine builder here so I'll take your word for it since I've only built/machined a couple engines so far.
I'm a little mixed up on how you explained my old main bearings, the rods have 634 and so does your example but my mains have 2121 on them and you put 509 for the mains?
Also I was planning on getting the rings that are listed here, the regular replacement I guess you could say (file fit .030) Part number 315-0049-035
from this website http://www.probeindustries.com/Pistons/Piston Specifications/PistonSpecs.htm
I'm definitly going to boost it in the futue so I'll make sure it's the non low tension rings. Do you know the number I would need for the right rings I need?
Here are some pics
Black1987Stang
1,422
Jersey Shore
Jun 28, 2008
#25
  • Jun 28, 2008
  • #25
so quick question, Should I go with P or H series if it's a forged crank and rods? I was thinking about the H, then again it came with the P series so maybe I'll stick with them?
I need some words of wisdom
Black1987Stang
1,422
Jersey Shore
Jul 7, 2008
#26
  • Jul 7, 2008
  • #26
ok so if I put it all together right now with the heads when they're done (65cc) and with a .040 gasket (assuming its a .010 still) deckheight I should have around 9.8 compression ratio, since I really want to boost it in the future I want to get it down to like 9 to1 at least, sound good? I don't want to get a HUGE gasket and kill the quench area
So should I just get new pistons? I can get one set that will bring it down to about 8.8 or so, but would that make it a dog while it's n/a?
one more question do ALL 331's have a 3.25 stroke? I'm not sure what kit this is and I don't have the fancy journal tool to measure it so I want to make sure it is in fact a 3.25 so I can order the right pistons and gaskets....?
Any advice?
Black1987Stang
1,422
Jersey Shore
Jul 7, 2008
#27
  • Jul 7, 2008
  • #27
Could I use just 91-93ish octane for 9.8 compression ratio if I put it together right now? with the mods and heads that are in this thread....?
First Prev 2 of 2
P
Engine Help 331 stroker
  • pdmount
  • Feb 19, 2026
Fox 5.0 Mustang Tech Feb 21, 2026
pdmount
P
My next project , a 428 build!
  • horse sence
  • Jul 29, 2026
  • 9 10 11
5K
Classic Mustang Specific Tech Thursday at 6:45 AM
DadLife0724
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
A
Engine 04 GT timing chain issue
  • AwesomeX1103
  • Sep 3, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Nov 5, 2025
R
Progress Thread 351w stroker rotating assembly and build
  • Ric4eyedFox
  • Mar 23, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 24, 2025
