nasty brown frothy antifreeze in res?
IndyBlk5.0
1,122
New Whiteland, IN
Weird thing is, i put a 2 liter ghetto rig on my car for the res becuase it was overheating and i didnt want to loose all my antifreeze everytime. But why would it be brown nasty and frothy? What is up with that? I even see this nasty brown stuff at the bottem of the bottle
Jerry Leaming said:
yea it should float.
what does it smell like?
This stuff settles at the bottem, it smells like antifreeze, maybe just allitle big of exhaust smell but i think it just smells like antifreeze, it doesnt feel like a lubricant, and it comes off my fingers easily in the sink without soap
maybe carbon?
It still sounds like a head gasket.
Just never heard of that (dirt) in the res bottle.
Have you taken your rad. cap off(while the engine is running) and watched the coolant flowing?
Does it have bubbles coming out through the opening and is there froth in that area also?
Jerry Leaming said:
maybe carbon?
No froth at all, and it didnt seem to bubble, but then agian i was trying to get the air out of my system
Well just keep your eye on the res tank especially when you get on it alot. Mine was fine usually until i really reved the motor then i noticed the coolant level would start to rise.
Might of been just an air bubble like I said on the other post. But at least now you now what to look for.
The brown gritty crap may be an additive used to seal coolant system leaks. I can't remember the name of it right now but it comes in a bottle, is liquid, and very brown and once mixed in your system, looks as you described. Did you add a "stop leak" to your coolant, if not, have you not had the car long (maybe a previous owner added this nice product for you)? It will work for a time and will cover up problems.
Well that just sucks... And guess what guys, i looks like that form a gasket stuff is stuck one of my ports for my radiator, so who knows whats in that thing =( Hum i overheated with a cold upper radiator hose, pretty warm radiator cap? sound like water pump?
I have worked on his car. I noted that it holds abnormal pressure in the system but dosent over heat, I ran it hard and came back and it still had pressure but wasnt overflowing into the bottle.i removed the cap and it spewed antifreeze and emptied almost half the radiator. The oil is clean, no sign of gasket failure, Exhaust looks good not steamy. I am leaning toward a weak waterpump..... or rad clogged. I just installed his heater core. Sometimes the system will just blow over on him. I thought head gasket also but still not convienced yet.
