So I just got done with my buddies NX wet kit install. I actually put the main system in a while back but finnalt hooked up his MSD window switch and tach adapter (Thanks Stangnet!)
So after finnaly figuring it out and setting it with what works rather then what the manuel says. It says to set the window switch to mode one for the COP setup but it was reading 8x to high so I switched it to 8cyl and reads correctly now.
Anyway I am wondering what would be a good starting point to set the window switch. I have it turning on at 2500rpm and off again at 5500 rpm. This is on an 03 GT with a C&L upper plenum and CAI with air meter, a larger T-body (not sure size), MAC O/R H-pipe, Basanni catback, 4.10's and a Diablo tuner. The nitrous is set for a 100hp shot.
Anybody else running one of these? What on/off points do you have set?
And here are a couple shots of my handy work. I miss seeing two Stangs in my garage
