NAWZ!!! Question.
LaserSVT
3,548
233
So I just got done with my buddies NX wet kit install. I actually put the main system in a while back but finnalt hooked up his MSD window switch and tach adapter (Thanks Stangnet!)
So after finnaly figuring it out and setting it with what works rather then what the manuel says. It says to set the window switch to mode one for the COP setup but it was reading 8x to high so I switched it to 8cyl and reads correctly now.
Anyway I am wondering what would be a good starting point to set the window switch. I have it turning on at 2500rpm and off again at 5500 rpm. This is on an 03 GT with a C&L upper plenum and CAI with air meter, a larger T-body (not sure size), MAC O/R H-pipe, Basanni catback, 4.10's and a Diablo tuner. The nitrous is set for a 100hp shot.
Anybody else running one of these? What on/off points do you have set?
And here are a couple shots of my handy work. I miss seeing two Stangs in my garage :(
I am using that exact window switch. As stated above, I wouldn't spray at any rpm below 3000. Your upper limit is up to you, but don't go over 6000. With a 100 shot and 4.10's, I am crossing the finish line nearly right at 6000.
Also, mine works fine with the 1 cylinder setting.
No lower than 3000 RPM....that should prevent a backfire. Shut off around 5800....as long as its before the rev limiter.
If its over a 100 shot...I would set it to 3250-3500RPMs.
what he said. i never had a window switch but when i was over a 100 shot i hit it at 3500 and never below 3000. and just make sure it shuts off before the limiter and you will be good to go
Thanks guys for the input! :nice:
The setting on the window switch bugs me though. I looked all over the internet but it turns out 4.6Tech was the best help for wiring it up :rlaugh:
Where I got the signal wire for the tach adapter was pin 34 on the large connecter by the fire wall. I cut and intercepted the signal. When I first fired her up I had the window switch set on mode one (as per the instructions) but at idle it read 8K :scatch: I switched it to mode 8 and had my friend rev to 2k then 3k then to 4k and it read correctly :shrug: I bet if I would of taken the signal from a single coil then mode 1 would of worked... I think :scratch:
I also dont understand why I couldnt just get a signal from one of the signal wires to a single coil? I didnt try but I know from reading on here that it wouldnt work.
Tim2002GT: Where did you get your signal from?
Huh, the instructions on this one said to cut the main power wire to the coils. Red wire to the puter and the red/green wire to the coils :shrug: I didnt like the idea of cutting the factory harness like that but I had seen the previous owner cut other wires in a few places already.
