• Community Forums
  • Regional Forums and Event Information
Need 8.8" rear info
  • Thread starter Thread starter Mr.$h!t$t@rter
  • Start date Start date Apr 7, 2006
M
Mr.$h!t$t@rter
22
London, Ontario Canada
Apr 7, 2006
  • Apr 7, 2006
hey everyone
does anyone know off hand the diffrence in length of a 94-98 8.8" rear and 99 to 04 rear end? I am converting my V6 to a V8 and I would like to know if I can get away with using a SN95's 8.8, for that matter I also heard the 8.8 used in the lincoln mark VII LSC was wider than the fox mustangs, anyone know if the width would be close to what I need cause those would be cheap to come by
thanks
Ron
R
Red2000GT
2,450
Regina,Sask.Canada
Apr 7, 2006
  • Apr 7, 2006
I have always been told that the difference was about 1.5 inches total(so 3/4 inch per side). I don't know about the rear end from the Lincoln but I"d imagine you'd have to change a bunch of control arm brackets to make the swap possible.
aete2
554
  • Apr 7, 2006
The 94-95 8.8 is the same as the fox 8.8 in size the 96 and up from what im told is 3/4 wider on both sides. Hope this helps!
M
MatthewP
355
Calgary, Alberta
Apr 25, 2006
  • Apr 25, 2006
The housing is the same, but 94/95 axles are longer than 93 and earlier axles. I think the difference is 3/4" on each axle.
-Matthew
Silvr04GT
1,131
San Jose, CA
Apr 26, 2006
  • Apr 26, 2006
Hey if you wanna do a 5-lug swap I've got a nice set of brakes with only 13,000 km off my GT sitting here!
aete2
554
  • Apr 26, 2006
-Matthew
if they are its not noticable direct bolt up can't tell the differance.
M
MatthewP
355
Calgary, Alberta
Apr 26, 2006
  • Apr 26, 2006
If you stand the axles up side by side on the floor, you can easily see the difference. The axles are longer to accomodate the disc brakes on the rear of the 94+ cars.
-Matthew
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Cobra 8.8 differential rebuild shop question
  • Sestemybe
  • Aug 5, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 15, 2025
baileygruwell
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
M
What changes need to be made to the brake system after swapping a V8 rear axel into a V6 1999
  • MARTYMAN
  • Jan 21, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 22, 2026
Mustang5L5
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
  • Community Forums
