Need '98 Cobra fr. rotor thickness tolerances
Can't tell you the specs but i can tell you when i had stock rotors on my 98 cobra I was close to min. specs on pad change, two weeks later busted a rotor and had a very bad day.. close to cliff, just my input, dont know your situation but mine were good and.. ya..
It should be stamped somewhere on the rotor. Check the attachment for the specs in the shop manual.
If you are close to min spec on pad change and you turn the rotor, chances are you will go beyond spec before you put the new pads on.
