Need a couple of How-to's
Why do you need CC plates? I would let an alignment shop install them if you need them. You will have to get it aligned anyways. Subframe connectors should be welded in, not bolted. If you have a good gas welder, take out the seats and pull back the carpet before welding. It can be done with the carpet in, but is safer if carpet is pulled back. :D
