- Apr 30, 2002
- 209
- 0
- 0
I have the spindles, rotrs, calipers, brakes, new bearings , ect. on the car now i need to run some new brake lines.
Question is i bought a new drum/drum master cylinder for my 68 V8 Coupe and now that i decided to swap to manual disc brakes on the front will the drum/drum master cylinder work? If not which master cylinder do i need/shoud use? Also the distribution block do i need to change that? Thanks for your help!
. You can get an adjustable propotioning valve. I am not sure what setup a 68 has stock as far as distribution/prop. valve.
