Need a pic or diagram of vacuum lines
Here's some help for the vacuum lines - Red line goes to the fuel pressure regulator.
Speed density cars: One goes from the manifold to the MAP sensor on the firewall behind the upper manifold.
Mass Air cars: NO connection goes from the manifold to the BARO sensor on the firewall behind the upper manifold.
There is a cluster of vacuum lines on the passenger side wheel well. A plastic sleeve covers the colored part of the lines: push it back to see the colors I am referring to.
One white line from the vacuum line cluster goes to the rear smog pump valve. One line goes from the manifold to the red line on the vacuum line cluster. One green line from the vacuum line cluster goes to the EGR, The black line from the vacuum line cluster goes to the from smog pump valve.
One large vacuum line from the front goes to the carbon canister control solenoid.
One large line goes to the vacuum tree
One large line to the PVC valve.
Some help from Tmoss (diagram designer) & Stang&2Birds (website host) with a picture...
Diagrams courtesy of Tmoss
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds
(website host) for help on 86-95 5.0 Mustang wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 88-91 5.0 Mass Air Mustangs
Complete computer, actuator & sensor wiring diagram for 91-93 5.0 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 94-95 5.0 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
