Guero said:
how would i take the shavings out??????
Here is the first thing that comes to mind you might wanna check
Look at the drain plug as it is magnetic IIRC.
If you see signs of the cam/dizzy gear chewed up
OR
A trashed cam lobe/lifter
OR
ANY kind of nasty looking places where it is evident, metal to metal contact has been going on ............
btw ... didn't you say you had some loud knocking happening?
If you see that kind of thing, that most likely was the source of the knocking.
Then ................
Look in the bottom of the pan for shavings.
Split apart the oil filter to see any sighs of the shavings.
It would be a good idea to check and see if any shavings have embedded themselves in the cam, rod, or main bearings.
I'd also check inside the oil pump.
If you find any shavings ..........
The only way to know for sure is tear it down to see how bad it is.
Grady
