need advise; power range at about 5000 RPM
reyesjo
66
"UPDATE"power range at about 5000 RPM
I have a 66 stang, with the following.
5.0 L out of a 1989 mustang with AL9P computer
mass air flow, and a 5 speed t-5 with an 8" with 3:55 gears
The engine is stock an has been rebuilt as well as the transmission, it has a T-Rex fuel pump and Windsor Fox wiring. the car starts great and runs great... HOWEVER.. in 1 and 2 gear about 5000 RPM the car runs out of power... It feels like the computer is not letting the injectors push out more fuel... I can't be exact on the RPM I'm lacking a Tech for now.. Don't know what it could be.. If you guys can think of something let me know please
http://www.cardomain.com/ride/2215774
It may be more like 6000 and you are running out of air.
HistoricMustang
www.historicmustang.com
Welcome.................
No problem, the stock head/cam/ intake combo run out there. I found the best shift point in a stock 5.0 to be 5600 r.p.m. for the best E.T. Give or take a few hundred r.p.m. for gearing differences but never over 5800 r.p.m. Open up the intake tract from start to end.
Check to make sure that the #5 and #6 spark plug wire are separated by a few inches (the plug wires should be in some kind of clips or harnesses to keep them separated). On a 5.0, the firing order is 1-3-7-2-6-5-4-8 - Check a Chilton's manual if you're not sure which is which, but 5 and 6 are the two front cylinders on the driver's side. Without going into the physics, it's possible for the #6 wire to induce an early spark in the #5 wire if they're too close together, creating an effect something like pre-ignition in #5.
When I got my 5.0l conversion running for the first time, it missed a bit at the top end. Separating the plug wires made a remarkable difference. Easy and free to try...:D
Thr problem is not the computer, but that the intake tract on the engine wont let any more air in. Stock 5.0 roller engines run out of steam around 4800-5200. The stock rev limiter is ~6200. Do you have an A9L or A9P computer? A9L is out of a manual car, P = AOD trans.
replys
Thanks for the fast replys,
I have a A9L for manual transmission, I will try to add a tech on her, but money has been tight... forgot to mention it has a K&N air filter just a cone at the end of the mass airflow metter..
Also the sensors going to the trasmission the Neutral sensing switch, backup lamp switch and the speed sensors.... are not hooked up... Only concern with the SPEED SENSORS, do they need to be hooked up..
thanks again
Vehicle speed sensor doesn't have to be hooked up, although it can improve driveability a bit if it is (it'll ramp engine speed down more gradually if it senses that the car is moving than it would if the car were still). That's not your high-RPM problem.
I think I made progress maybe, still no Tach
Ok gents, let see what you think.
I disconnected the MAP sensor electric connector.. the vacume line was not connected... It feels like it has more ump, more power.. what do you guys think..
The MAP sensor is for Speed density I think... SHOULD IT BE HOOKED UP?
I don't know hopefully I will get a sticking tach soon, I have a bid on ebay for one..
well technically speaking on a mass air system its called a barometric pressure sensor. electronically its the same as a map sensor, only difference is that the map sensor has a vacuume hose hookup where the baro has a little filter. if the vacuum line was hooked up this would probably give you a problem. i think on the eec-IV the computer takes a reading when the key is first turned on and at wot, if ther was a little vacuum there the comp would see a drop in atospheric pressure and lean you out a little.
when i did my first efi conversion i had no air filter so i zip-stripped a couple rags to the throttle body to see how it ran. i couldnt get over 2500 rpm and it ran just fine there smooth as silk at wot. it took me awhile to figure out what the hell caused that i thought it was the rev limiter because i didnt have the neutral sensing circuit hooked up.
update, got a Tech on her
Well, I finially got a Tech on her, and to my surprise the engine runs like a bat out of hell up to 5K RPM and as soon as it get to 5K it feels like it looses power....Is that normal for a stock 5.0L.. I think that if I shift around 5.2K or alittle higher it runs great.... I just have to learn to shift faster.... I guess..... or start saving money to upgrade the engine. If only I could convience the wife to take money out of savings.
On all the stock parts, yes. Depending on how many miles are on the engine, you might run into valve float before the 6250 rev limiter. However, you know first hand that its unnecessary to rev that high because the induction runs out well before that.
