need alot of help with my new 99 cobra
i just baught a 99 cobr. first thing i did was buy a tuner <diablo predator> i think i set the rev limiters to high the call is fully stock only thing on it right now is cold air induction , need to no what the limiters shoud be set at for a stock cobra. also looking to get new gears for the rear and was wondering if there is any truth to the fact that cobras rev out higher and i should go with a bigger gear then 390s
No higher than 6800 rpm(what is stock) otherwise you will do damage to the valve train as the stock springs and all cant handle 7-7500 rpms..
Gearing for a NA car would be 4.10's or 4.30's for an IRS cobra.
well
Keep the rev limiters at 6800, no reason to rev past that. I don't understand what you are talking about in 3rd gear thing. :shrug:
Yes you have an 8.8 rear end and need the standard ford 8.8 gears even though it's an IRS. checkout svtperformance . com and read the FAQ section on your car. Then AFTER READING THAT, if you still have any questions, ask away.
