  • 1994 - 1995 Specific Tech
Need Answer ASAP - Priming Oil Pump
  • Thread starter Thread starter Danman765432
  • Start date Start date Jul 8, 2008
D
Danman765432
471
Nutley, NJ
Jul 8, 2008
  • Jul 8, 2008
I am currently trying to prime my oil pump I did it for about a minute and a half and no oil came up by the pushrods yet. I was wondering do you go full speed in reverse with the drill or go slow. Right now I have been at about medium speed since I didnt know which on to do.
Also how long does it take to get oil to the pushrods and rockers?
Also the drill starts getting jerky when doing this...my guess that is it pushing the oil through the pump?
rj95svt
422
Hayden, AL
Jul 8, 2008
  • Jul 8, 2008
It may take a few minutes to get oil to the top of the pushrods but you need to verify that you get oil to to the top of the motor before installing the engine. I ran the drill at full speed. I ran into a problem and wasn't getting oil to to the driver side lifters caused by a stopped up oil passage. This is not a problem you want to find after the engine is in the car trust me.
D
Danman765432
471
Nutley, NJ
Jul 8, 2008
  • Jul 8, 2008
Yeah I just replaced the head gasket but the car has been down for the past few months.
Also should i put oil where the distributor goes?
Right now I have 5 qts in it and and the dipstick reads full, but when I look down the distributor hole there doesnt seem to be any oil
rj95svt
422
Hayden, AL
Jul 8, 2008
  • Jul 8, 2008
As long as the dipstick shows full you should be ok but it would not hurt to put some oil on the distributor gear before installing the distributor.
RIO5.0
6,892
N.H.
Jul 8, 2008
  • Jul 8, 2008
Yes you want to run in reverse....It may take awhile to bleed out your pushrods...Have someone turn the key on as your priming it...your gage should read when it sees pressure...
D
Danman765432
471
Nutley, NJ
Jul 8, 2008
  • Jul 8, 2008
Hey guys I got it going really easily after i noticed something... The autozone rent a tool stripped on the inside and was just spinning around on the pump... I then just taped a bunch of sockets and extension together and got pressure in a matter of seconds. It took about 30 seconds for it to come out of all the push rods.
SQUEEZE&STROKE
SOUTHERN CA
Jul 9, 2008
  • Jul 9, 2008
Good old AZ...
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
Oil choice for after break in period.
  • Sask84gt
  • Feb 28, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 14, 2026
Praetorious
P
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
D
89 foxbody fuel pump not priming
  • Dubsantana
  • Jul 6, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2025
AeroCoupe
