Need Aussie valve train recipe
  • Thread starter Thread starter Ponydrvr72
  • Start date Start date Sep 22, 2009
Ponydrvr72
70
Watertown,NY
Sep 22, 2009
  • Sep 22, 2009
Hi gang, I ordered a set of aussie 2v heads from Ausford. I plan to have them machined down the street,they will be going on top of a 351C 2v remanufactured 10k ago. I ordered from PAW a comp 270H magnum cam,comp
hyd anti pump up lifters, comp single valve springs and retainers. I think I am alright so far. depending on the feedback i get i was planning to order the following parts to finish this offaw Molly push rods, polly seals, multi groove keepers, paw stainless valves, Ford racing roller rocker arms. If anyone w/ experience with these heads can give me insight on my recipe or their own proven formula please let me know before i sink a grand into these heads. a couple things i am curious about are valve size's, ohio vs australia and pushrod guides, the Ford arms are bolt on with no guides needed. some extra info on the block,4v 600cfm performer carb,2v performer manifold,hooker comp headers,FMX/stock converter,9in. 2.75 open rear end,soon to be 3.00 traction loc. thank you's in advance for any help you can give me. Scott
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Sep 22, 2009
  • Sep 22, 2009
I don't know who manufactures PAW 's house label valvetrain parts, but I would be leery. In the past I have found that their house label parts are cheaper for a reason, so I don't buy them anymore.
woodsnake
1,352
15
69
Hicksville, NY
Sep 22, 2009
  • Sep 22, 2009
While I can't speak directly to your parts list, I'd like to point out that the valve stem length may have to be determined by the springs and the cam, as well as the push rod length.
Also, make sure that your machine shop understands that Cleveland heads are different than Windsor heads!!!!!
65ShelbyClone
4,675
38
119
Sep 22, 2009
  • Sep 22, 2009
Durr....wrong thread. Sorry.
C
C0V3R
524
Australia
Sep 24, 2009
  • Sep 24, 2009
If you want a set of the best aussie clevelands youll ever get, get TK on performanceforums to build and port them for you.
Do a search on there and check out his porting work. Its second to none.
If the heads are already in the state I guess you can ignore this, but if they havent left australia yet, give TK a yell.
Ponydrvr72
70
Watertown,NY
Sep 24, 2009
  • Sep 24, 2009
actually i dont know where the hell my heads are, ordered them on the 10th. and ausfordparts web mail dont work. when they do arrive i will just go with what i know..... what i am most concerned with is valve stem height after the valve job.
C
C0V3R
524
Australia
Sep 25, 2009
  • Sep 25, 2009
By most accounts you dont need to change the valve size on the 2v's. A little tickle porting them is usually all you need.
R
Advice Needed On 1969 F Code 302 2v Motor Stock Rebuild
  • RudyK
  • Dec 22, 2017
2K
1965 - 1973 Classic Mustangs -General/Talk- Dec 22, 2017
RudyK
R
My 95 v6 to v8 conversion project. Advice needed
  • Stangzpride
  • Jul 27, 2018
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 30, 2018
Stangzpride
'67 Mustang 289 V8 Rocker Arm Poly Lock Nuts Keep Coming Loose. Wtf?
  • cjstang6791
  • Jul 18, 2016
  • The Welcome Wagon
3K
The Welcome Wagon Jul 18, 2016
Davedacarpainter
Fox Engine Build Advice
  • JasonFOXBOD
  • Jun 17, 2015
8K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 19, 2015
FastDriver
  • Locked
SOLD 2000 Mustang Gt (2.1 Kenne Bell, Stroker, Suspension Etc..)
  • 5.0 gt dreamer
  • Dec 17, 2013
16K
SN95 Mustangs For Sale (1994-04) Jan 22, 2014
5.0 gt dreamer
