need c4 info asap help!!
h82lose72
i have a 91 5.0 and i want to put a c4 behind it. i found a good tranny but im sure if its right for the car. do i need a10 1/2 bolt circle or 11 7/16 what about case or pan fill then theres the converter spline what is best and will it bolt right in or do i need driveshaft and crossmember mods? the car was a five speed. the tranny i found is from a 68 mustang. what is it?? also what flex plate do i but 28 or 50oz and 157 or 164 tooth??????????????
You can reuse the cross member and the drive shaft. You need to measure your bell housing because c-4's come in large bell housing and small. Large you can use the larger converter with a 164 tooth. A stock aod or aodE flex plate will work if its a large housing it's also a 50oz what you need. Get a good shifter also. Case fill means that your dipstick is mounted inside the case. Pan fill mounts on the side of the pan, in the pan itself. Make sure you count the splines before ordering a converter
If you are starting from scratch, either large or small will work.
My 79 Capri came stock with a C4 and had a large 168 tooth flexplate etc.
You need to match the balance to the engine, (50oz in your case), and then make sure you have the matching block plate (to locate the starter), flexplate converter and trans. The large flexplate is also used on the aod.
The 68 trans may work but valvebody upgrades will be easier with the later ones, as already noted.
