ok here is the deal. i know a custom cam would be best but i dont want the spend the $$$ and i dont want to do a roller conversion ($$$$).
the mods go like this
new 351w 9:1 forged
GT40x aluminum heads
cobra extrude honed intake
75mm TB
C&L 76mm maf
24# injectors
bbk 1 3/4" long tubes 3 " exhaust to dumps
5 speed (poor T5)
4:10 gears
all in a 86 coupe
the goal is a bad ass street car that will see limited street use.
anysuggestions?
here are the potential cams
http://www.powerandperformancenews....ory_Code=35-CAM
Camshaft Specification Table
Part Number 35-254-4
Engine 1969-1995 Ford
351ci,
Windsor,
Grind Number FW XE294H-10
Gross Valve Lift 0.554 0.558
Duration At 0.006 Tappet Lift 294 306
Valve Timing At 0.006
Open Close
Intake 41 73
Exhaust 87 39
These Specs Are For The Cam Installed At 106 Intake CL
Intake Exhaust
Duration At 0.05 250 256
Lobe Lift 0.347 0.349
Lobe Separation 110
Part Number 35-246-3
351ci,
Grind Number FW XE274H-10
Gross Valve Lift 0.519 0.523
Duration At 0.006 Tappet Lift 274 286
Open Close
Intake 31 63
Exhaust 77 29
Intake Exhaust
Duration At 0.05 230 236
Lobe Lift 0.327 0.327
Lobe Separation 110
Part Number 35-226-3
351ci,
Grind Number FW 280H-10
Gross Valve Lift 0.512 0.512
Duration At 0.006 Tappet Lift 280 280
Open Close
Intake 34 66
Exhaust 74 26
Intake Exhaust
Duration At 0.05 230 230
Lobe Lift 0.32 0.32
Lobe Separation 110
Vendor Ford Racing Performance Parts
Product Line Ford Racing Camshafts
Cam Style Hydraulic flat tappet
Basic Operating RPM Range 3,000-6,800 RPM
Intake Duration 050 inch Lift 236
Exhaust Duration 050 inch Lift 246
Advertised Intake Duration 296
Advertised Exhaust Duration 306
Intake Valve Lift with Factory Rocker Arm Ratio 0.520
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.538
Lobe Separation (degrees) 109
Intake Valve Lash (in) 0.000
Exhaust Valve Lash (in) 0.000
Grind Number SM-6250-A351
__________________
My Car
WTB: 67-69 Camaro
new 351w 9:1 forged
75mm TB
C&L 76mm maf
24# injectors
5 speed (poor T5)
4:10 gears
all in a 86 coupe
anysuggestions?
351ci,
Windsor,
Open Close
Intake 41 73
Exhaust 87 39
Intake Exhaust
Lobe Separation 110
351ci,
Open Close
Intake 31 63
Exhaust 77 29
Intake Exhaust
Lobe Separation 110
351ci,
Open Close
Intake 34 66
Exhaust 74 26
Intake Exhaust
Lobe Lift 0.32 0.32
Lobe Separation 110
__________________
My Car
WTB: 67-69 Camaro
