  • SN95 4.6L Mustang Tech
Need Cam Help ASAP??
  • Thread starter Thread starter IJUSTWON
  • Start date Start date Dec 2, 2004
I
IJUSTWON
242
  • Dec 2, 2004
Most Already know of my setup 5.1 .020 bored aluminum Block, Forged Internals, bbk headers, bbk underdrive pulleys, bbk t/a, o/r x pipe, flowmaster catback, 3.73 gears. I am now looking for a set of cams for this setup. Also, i plan on staying N/A. I see threads on VT and Comp. Need some input on which is better of the two and also if you already have them chime in on what Numbers they gave you. Going to P&P heads later on down the road if that helps any?
I
IJUSTWON
242
  • Dec 2, 2004
mogs01gt
3,113
30
119
Ohio
Dec 2, 2004
  • Dec 2, 2004
Didnt you already post this?? Do some searches. There are millions of threads on this exact question.
VT stage 1s would be my first choice and Comps as my second. You might want to invest in some taller gears.
J
johnnyvista
123
  • Dec 4, 2004
i have a set of comp 278s with the 5.1. love em. they go together like peas and carrots.
J
johnnyvista
123
  • Dec 4, 2004
268s, i mean.
I
IJUSTWON
242
  • Dec 4, 2004
So ComPCams 268's are better than VT stage 1 or 2?? The motor is gonna be kept N/A and i'm trying to figure out what setup to go with i seen CompCams 274's is that too agressive?
nickthegenius
1,631
Elwood, IN
Dec 4, 2004
  • Dec 4, 2004
With a nice built shortblock, why go with wuss cams like the VT Stage Is? Yeah, they can make OK numbers, but why put a set of mild cams on a fully built block? With more aggressive cams and ported heads later on, you should make some killer numbers now and even better down the road when you get them ported.
Depending on piston to valve clearance or your specific shortblock (depends on piston dish), don't short-change yourself and get a set of Comp XE270AHs, VT Stage II, or call Tim @ T&J and see what kind of custom grind you could get from him. IIRC, his custom cams aren't any or much more than an off-the-shelf set.
Oh, and BTW ditch the 3.73s. They're killing my times with 270s. I'm going with 4.10s or 4.30s before the tracks open next spring.
billyfe390
573
  • Dec 4, 2004
I figure I'll answer him on the 4th or 5th time he asks this on here or the depot.
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
F
carb vs cam help needed
  • forango
  • May 2, 2024
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2025
forango
F
J
Holly High ram setup on 347ci SBF NEED HELP
  • Jschallitz
  • Jun 7, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 7, 2024
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Fox Build ideas for the 'Hudson Heap' (87 GT)
  • MadSquirrelTech
  • Sep 19, 2023
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 27, 2023
MadSquirrelTech
