- May 28, 2005
- 9
- 0
- 0
I rebuilt the carb on the 86. Looked easy enough,the accell. pumps rubber was cracked/tore. Put it back together with the new stuff,adjusted the new float per instructions. It'll crank but when you give it gas it just dies. I've adjusted the screw on the passenger side from all the way in to all the way out. Any help would be greatly appreciated as I know very little bout 1bbl carbs and even less bout the 4 banger. Is there a wrong way to put the TPS back on? or maybe Choke bad?
