Need comments please
new46stang
146
AZ
What do you guys think of this hone job? Block was bored and torque-plate honed.
Look at the lip of the cyl. at about 12 o'clock.... :shrug:
Also, need advice on dealing with spiral locks for my Probe pistons/rods. What is the best way to install these things?
TIA
Matt
The area at 12:00 is not to much of a concern, shows sloppy workmanship, but it is at the top of the cylinder, the rings will not come up that high in the cylinder to cause a problem. I concur that the hone job is on the rough side. Should have used a 600 grit stone. Looks more like 300 to me.
One other important note: There is WAY to much lint from a red shop rag on the head surface. if that gets into the engine it can cause the oil pump pick-up to become plugged and cause a loss of oil pressure and then the hole thing becomes a big pile of worn out parts fast.
Can't help with the spiral locks, but I have to concur with the roughness of the hone. What type of rings are you planning on running? I'd ask the machine shop what the final hone was done with. I'm totally going from memory here and I don't remember where I heard/read it, but I think with moly rings, you want something like a 280 grit final hone, so that would be about right... however I could be totally talking out my *** here.
Thanks for the help All. I will ask the machine shop what stone they used. As for the rings, I believe they are plasma-moly file fit Perfect Circles.
A concern I have is that they bored it and then did the torque-plate hone to bring it to the finished spec. If they have to go over it again with a finer grit would it take it out of spec?
I really am disapointed with the way it looks. :(
Bullitt347, Ya I know there is a lot of lint on there. When I painted the block, after I pulled all the masking tape off, I used a bit of brakeclean and the "red rag" to wipe down a little overspray.
The block really hasnt been cleaned yet and I am no where near putting it together until I find a solution for the spiral locks. My theory is clean it, then clean it again and once it's clean better do it one more time.
Thanks again.
Matt
Ok so called the machine shop. He states that they use a "501 stone and then a coark stone (coark somethin) real quick to knock off the edges. That's how we prep all our race blocks with moly rings).
I'm wondering if they forgot a step and thought they were done and gave her to me? I'm gonna pay the $50 for the pistons to be put on the rods. That solves my spiral lock issue. Perhaps I should take the block back down and ask them to take a look at it?
Matt
