As I've posted in other threads, my car started missing all of a sudden. Pulled codes, checked EGR, nothing. All wires and plugs are working. So I checked compression.
Cylinders 7 and 8 are showing 60. All other cylinders are at 150, except cylinder 1, which is at 148, and cylinder 4 is at 140.
I didn't think to put oil in cylinders 7 and 8 to see if it brings the pressure up, but I will. I'm thinking I have a blown head gasket? I am getting some white smoke, but I'm also getting blue smoke. No water in the oil, and it doesn't appear that I have any oil in the water. Of course I was almost home when it started missing, and I haven't driven the car since, other than running the car running tests.
Two questions...the car has been using a lot of oil...could a weak head gasket cause this, and maybe it just now gave way?
Also, the car has been pinging bad when I pull out...could this be associated with a blown head gasket?
