need good advice to get started
mustangman140
12
well went to go to work and coolent under car. yeah! well got under tried to fix thought it was lower hose nope. i have i little leak from a bolt that is on the other side of the waterpump bolts. There are only two from bottom and there don't look very easy to get can some tell me what they are for and should i just put another water pump on so that i re seal everything. by the way waterpump still good probly been in car 5 years
Is it leaking out of the bolt or the weep hole? If it's just a bolt you can probably unthread it and put some new pipe dope on it to get it to seal back up.
More than likely though, once you start that the coolant will begin leaking out of the gaskets and then the weep hole. So you might as well just take off the whole front end and do it right.
