Need Hekp: Problems after H/C/I install
lopey4.6
Jan 4, 2004
309
Westlake,OH
New mods are in my sig. I fired it up for the first time and the car won't hold idle. There are no leaks, smoke, or bad smells. I had to adjust the TB set screw for it to hold idle. I have a autologic chip that was burned for the old cams I had in there (XE270AH). I'm waiting for the throttle cable so I can drive it, but seems like the cam timing is good, no back fireing through the intake, no sucking sounds, car sounds very good when I rev it up. Any ideas? Also I forgot to mention I did a EGR delete and I have a SES light.
Next problem is I have a soft knocking sound from the passenger valve cover. How should I go about diagnosing this?
Thanks everyone for the input in advance.
__________________
01 GT 5 speed:
Old nunbers: 100 shot dry: 375 rwhp 504 rwtq
Tuned by Kauffman's Motorsports
Almost done: P&P heads,oversized valves, Comp Cams stage III, Bullitt intake, Aeromotive rails, 150 shot, spec stage III, Auburn pro, Mosier 31 spline, Mezeire wp, ARP stud kit, Prothane MM. New numbers coming soon
Ever think that maybe you need to retune the car? You add ported heads and Comp XE278AHs (Stage IIIs) and expect it to run correctly off of your last tune?
Also, as far as the EGR goes is it shut off in the EEC with your chip?
I would pull the plugs get a small but intense flashlight and look down into the bores or if you have a boroscope use it. See if you have PTV contact. Also, make sure that you swapped the cam spacers onto the new cams. Could be the sprocket walking back and forth. I had that problem when I installed mine and forgot one of the spacers. Did you bleed the lifters? Some guys on Modular Depot didn't bleed theirs and it causes some sort of problem if you don't bleed them and let them pump back up with the new cams but I can't remember the details. Lastly, it just may be increased valvetrain noise that is sometimes associated with aftermarket cams, etc. Mine has some extra noise (very slight) but no signs of PTV contact so I've just chalked it up as increased noise due to the cams' profiles.
lopey4.6 said:
Thanks everyone for the input in advance. (also I'm a converted stangnet member because their tech sucks )
Nice copy/paste job :rolleyes:
