need help 07gt v8 cat converter removed
biljeek
hi all
cat removed with mid x pipe and magnaflow catback
i am facing a slight problem after i removed my cat converter, the issue is every time i push the clutch while stopping or down shifting the RPM goes under 5 for few seconds then goes to idle and some time this cause turn the engine off, this also happening when i rev the car while stopping.
do i need to tune my car with SCT tuner? is the tuner gonna solve my issue?
You definitely need a tune to cut off the oxygen sensors and tune the engine. If I were you, I wouldn't even drive the car:no telling what the sensors are telling the engine. I'm actually surprised it runs at all; probably in limp home mode.
+1 no cats = you need a tune.
In these cars the computer is so sensitive that if you mess with the headers or cats and dramatically change the exhaust characteristics or it'll act up.
